The fill valves are likely interchangable, not sure about the flapper valve. On many of the Toto's one uses a blue one and the g-max uses the red one. Using the red one will DECREASE the amount of water that gets used in the flush, so it might make the flush worse. The red ones are designed to close faster (because of the hole you can see in the lower part) than the blue ones.
