Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: PF/2 Energizer-actuater valve breaks
    DIY Junior Member TSHORE's Avatar
    Feb 2008
    Minnesota
    Default PF/2 Energizer-actuater valve breaks
    Our PF/2 is almost 4 yrs old. A month ago the Actuator valve broke, and the company sent us a new one - under the 5-yr parts warranty. Now, one month later, it has broken again - which just lets the water run and the toilet will not flush. Is there something fundamentally wrong with the whole tank unit, that we should be replacing the whole thing?
    Thank you.
    Former Consumer Reports "Best Buy"
    Do they even test toilets before they write their reports?
    http://www.terrylove.com/forums/sear...archid=2130826
    PF/2 Energizer, found in Eljer
    Someone emailed me wanting to know about parts for these today.
    Since I have never sold one, I didn't know that there was a local place in Seattle, and someone in Florida that had parts.
    I did send him back a link to the Flushmate site that has a replacement tank for the obsolete PF/2 Energizer.
    That wasn't good enough for this dude.
    He expected that I would know the cheapest way to fix his cheap toilet.
    He didn't call the place he bought if from, one of the home centers I'm sure, he called me.
    I know the home centers don't carry parts for these toilets, they just sell them.
    I don't have parts for them either. I carry parts for toilets that I do sell however.
    I have never recommended this particular toilet, I installed one in my home for a few weeks and that was enough.
    If I wanted everything out of the bowl, it took two flushes. The little high speed jet would mutilate the paper and float it back up at me, ha ha! Who thought of that nonsense. This puppy was good at the Consumers Reports way of testing, little rubber sponges and the like, but it was pathetic at flushing that nice soft 1 and 2 ply paper that goes on a roll.
    I gave the thing away. The women in the house were begging me to to dump the thing.
    I got one call to repair one in downtown Seattle one year, and lucky for me, I was able to find a replacement tank for the fix at that time.
    Jim,
    Sorry I didn't know who sold the linkage parts for your toilet.
    I know it was considered a Consumers Report "Best Buy"
    But it has been obsolete for some time now.
    It was a true dog, and I wouldn't have wished it on my enemy.
    You can find parts for the obsolete PF/2 Energizer Consumers Reports Best Buy here
    Somebody liked it though. There are Pit Bull lovers out there too.
    The PF/2 Energizer system has been discontinued. Sloan Flushmate offers a changeout kit for more fixtures. The kit contains everything needed to change out the system to Flushmate. Below is the list of OEM tank model numbers and Flushmate part numbers for the changeout kit.
    Crane Tank # 3612, FM KIT M-101526-F3CK
    Eljer Tank # 141-7000, FM KIT M-101526-F3EK
    Peerless Tank # 1, FM KIT M-101526-F3PK
    http://guillens.com/pf2/default.htm
    and some other links
    http://www.chicagofaucets.com/pf2/pf2.php
    http://www.eljer.com/products/toilet...oubleshoot.pdf
    http://www.flushmate.com/changeout.asp
    DIY Junior Member Jeff_M's Avatar
    Dec 2008
    Massachusetts
    Default Help/Advice on "whining" PF/2 Energizer toilet
    I have a PF/2 Energizer, model 150-403 in an Eljer 141-700 (actually I have three of these). Two of them have developed a "whining" sound when flushed and one also has weakened flushing. Is there something a home handy-person can do to remedy this (I have the user guide and tools)?
    Thanks, Jeff
    Dec 2007
    Have a look see at this linked thread.
    http://www.terrylove.com/forums/showthread.php?t=19458
    No problem. Solution involves about $135 and about an hour.
    In my opinion, shame on Eljer for ever putting this off-brand oddball in their toilets, but on the other hand, Eljer is now merged with Crane and American Standard, so you can blame the whole crowd!
    DIY Junior Member qualityinnrick's Avatar
    Jan 2009
    Colorado
    Default Pf2
    Hi all. I know that this subject is a little bit old, but thought this was an important post.
    I manage several hotels. I purchased about 80 of the Eljer PF2 models about 4 years ago. The actuater valve will break. It's not a question of if, but when. I have had to train several maintenance people to replace them when they break. If you hope to find replacement parts...good luck. I have found that the best option is to simply replace the entire assembly inside the tank. I have also run into problems with the supply line. This is a new problem that I have found with about 5 units. But I am guessing that it will run through my entire hotel. The problem it that there are fittings on the supply line that are a type of clamp. They start to leak after a while. They will put water inside the ceramic tank but outside the plastic tank. It doesn't render them unusable, but you can hear water running. I believe that it just goes into the toilet. I've never had a tank over flow. They just get about 2 inches deep. I am thinking about using a worm gear type of clamp to try to replace the old ones. You can get a replacement unit from Gullins for about $120 but who wants to spend that kind of money because a clamp is leaking.
    Rick
    PS. These toilets were not really cheap. After the cost of a seat I spent about $250 each. At 80 units that was quite a bit of money. I consider them to be middle of the road. They did work great when they were new. We have not had to plung a toilet in years. It used to be several a day.
    DIY Junior Member ron vaughan's Avatar
    Mar 2009
    Kalama, Washington State
    Question eljer PF/2 ENERGIZER
    Doe's any one know how to recharge the pf/2 ?
    Dec 2007
    You replace it with the sloan retro fit unit.
    Is this a pressure assist toilet? If it no longer works, you'll either need to find the leak and fix that or replace the whole guts, if available. It may end up cheaper to replace the toilet.
    A pressure assist toilet gets its pressure from the water supply - you do not do anything to manually recharge it. If it can't hold the pressure, and it tries to work as a gravity flush toilet, it won't work very well at all.
    Dec 2007
    The PF/2 Energizer has joined the long list of defunct pressure assisted toilet mechanisms.
    It seems as if the only one to buy is the Sloan Flushmate.
    See the post at this link for parts information...
    http://www.terrylove.com/forums/show...67&postcount=2
    Comments by readers Reader Review's Avatar
    Jan 2006
    Are there replacement paerts for the pf-2 system? The problem I am having, is the pipes are starting to chatter while the toilet is refilling. I have 4 units, and this problem is only on 2 of the units. They are 4 years old, and I have replaced some parts about every year. Any ideas wy the pipes would chatter? Loose o rings?
    Garry
    Dec 2007
    It may just be a loose washer in the angle stop valve under the left side of the toilet tank...
    Make sure it is open all the way...
    DIY Junior Member spudster's Avatar
    Aug 2009
    Boise, Idaho
    Terry's opinions aside, the PF-2 has been a reliable unit for ten years in our household. Noisy, yes, but every bit as effective as we would have hoped with its CR best buy rating.
    Unfortunately, as qualityinnrick noted, the weak link in the unit is the actuator valve, whose pin snapped off after a decade of service. As is noted in this thread, replacement parts are still available, but harder to find. The actuator is not available separately. You have to buy an entire rebuild kit for $125. Guillens has rebuild kits. We got ours through Locke Plumbing, who like many, suggested a switch to the SLOAN innards.
    Rebuilding the PF-2 was a simpler task than fully replacing the entire guts, which, if I am not mistaken would have meant removing the tank in addition to the innards, so we opted for the rebuild. It took less than ten minutes.
    As for the suspected leak of the supply line that qualityinnrick mentioned, I found that the problem in our case was actually a small rubber plug in the main plunger for the unit.
    The large plunger is part of the rebuild kit and is located in the chamber in the middle of the unit below the hex-bolted lid. The plunger that came in the rebuild kit actually introduced the constant trickle of water from the tank into the bowl. But it was an easy fix once I figured out what was causing the problem.
    The large plunger is actually comprised of six parts. 1. Plunger cup 2. Large rubber gasket 3. Plunger shaft 4. Small rubber gasket 5. Small rubber plug 6. Spring
    The small rubber plug and spring are located in between the plunger cup and shaft. By unscrewing the shaft from the cup, the rubber plug and spring are accessible. If the small rubber plug is not centered in the small opening at the base of the plunger cup when the shaft is joined with it, water constantly leaks around the plug, drains down into the tank and trickles into the bowl.
    So, your goal is to center the small rubber plug in the opening, under the tension of the spring, and screw the shaft into the plunger cup. That should do the trick.
    BTW, when you disassemble the cup and shaft, clean the small rubber plug so that more leaks don't develop.
    Again, this took less than ten minutes to remedy. I looking forward to another ten years of dependable service from the unit.
    In the Trades Thepartsguy's Avatar
    Jun 2009
    Dallas TX
    The PF2 is no longer made for a reason. As for parts, WC Tech (makers of PF2s) has shut off all supply of parts to its suppliers and is now just dealing in warranty parts to end users. (till they run out). Sad too, I was making money hand over fist on these parts. I do stock the Flushmate change out for both Crane and Eljer.
    DIY Junior Member aardvark_rich's Avatar
    Nov 2009
    OC, CA
    I have two PF/2 Power Flush units in Eljer two piece toilets. When they are working, they do the job like no other can - the problem is the flush actuator is under designed. The material used in some soft, flaky, polyethylene or polypropylene. It is not intended to work under the stress it is subjected to by the spring. Every flush actuation forces the small threaded end which connects the valve end and pin back onto the seat and rubber washer until the randomly distributed flakes of poly let go.
    I have little cash to waste on waste disposal unit at the moment, so I took my Saturday and decided to earn the $125 for the only available repair/rebuild kit. Here is my (working) solution.
    1. remove the actuator valve assembly by unscrewing the actuator from the top "manifold".
    2. I assume your valve is already broken, so just reach in and retrieve the valve/pin end unit.
    3. Carefully remove the broken treaded end of the actuator stem from the valve/pin unit. Mine required melting a slot for a screwdriver with a soldering iron so I could unscrew the threaded end.
    (Caution: the next step requires skill with a hand drill - better to use a lathe, but who has one in their garage?)
    4. Drill a hole from the broken end of the actuator shaft all the way through the shaft. Be carefule to align the drill so it goes in the center and stays centered al the way through. The hole needs to be a close fit for a 6/32 screw.
    5. Buy a 6/32 x 2" brass screw from the hardware store. The spherical bump on the external end of the actuator should be flattened slightly so the end of the round-head screw approximates the same shape.
    6. Buy a small brass threaded insert from the hardware store. The type I used was a brass threaded wood insert with a 6/32 thread. It was the smallest one they had. Carefully screw the insert into the threaded end of the valve end/pin unit. Mine fit perfectly and still had enough space for the pin to move freely.
    7.The 6/32 x 2" brass screw should stick out the other end of the actuator shaft. You may need to trim the length by 1/8"- too long and it will not fully engage the valve/pin unit.
    8. Put the spring on the actuator valve and insert it into the actuator housing. Insert the actuator valve. Apply enough pressure on the valve for it to stick out of the other end of the housing.
    9. Thread the valve/pin housing with the threaded brass insert onto the end of the brass screw end.
    10. Carefully tighten the brass screw with a screwdriver and torque lightly.
    11. Reattach the actuator valve assembly to the manifold.
    12. Flush without fear - this will not break (unless the insert was too small and did not thread into the valve/pin unit correctly).
    The parts cost for this fix was under $1.00 - the first time I did it cost me a couple of hours of measurement and adjusting the process. It is simple, once you understand what needs to be done. I saved at least $124.00, and I can say that my inner MacGyver was satisfied...
    Aardvark_Rich
