I had a plumber do the roughing in for two pedestal sinks to replace a double vanity. Then had someone finish the wall behind after installing 2X6's to support the new sinks. Now, I'm wondering if I can install the pedestal sinks myself. Here are my concerns:
1) The drain pipe coming out of the wall is just flush with the wall now after the drywall was installed, and the guy spackled around the pipe so there are NO gaps. I'm not sure how to attach a p-trap that will fit to the drain pipe - what parts do I need?
2) When the new water supply pipes were moved, the plumber just capped off the ends of the copper pipes. How do I remove this caps and install the water supply shutoff valves?
3) THe pedestal sinks came with a bracket and most of the hardware but it appears that I need to buy lag bolts to attach the brackets to the wall. The screws in the package were not labelled so I don't know which is which.
Here are the instructions that came with the sinks:
