Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: NORITZ Tankless Heater--water temp fluctuation
    DIY Junior Member shall's Avatar
    Mar 2007
    Sacramento
    Question NORITZ Tankless Heater--water temp fluctuation
    NORITZ N069M TANKLESS Natural GAS WATER HEATER
    We installed a NORITZ IN March of 2007. We have had water temp fluctuation ever since. We have had several opinions on cause of problem to no satisfaction. First we reran 3/4 line direct to gas supply about 5'. Second we contacted PGE and they resized the meter upward to 630 btu which is almost twice the size needed. I contacted NORITZ and went through the test procedure and all results were well withing operating ranges for supply and demand of water including outlet temperature. The flow through the heater during shower use was registering 1.5 gpm so have plenty of capacity. The temperature rise is from 58 to 120 degrees. A 60 degree spread and the heater should provide 5.5 gpm at that level.
    The water pressure at the residence shutoff is about 60 to 70 during the day and does fluctuate a little within that range. At night the pressure has registered as much as 80 to 85 on the "WATTS'" Regulator Test Guage.
    The NORITZ people felt that the problem was likely in our plumbing --like the MIXET valve in the shower. If the shower is in use the temp fluctuates slightly. If water is used any other location a dramatic change occurs. Not very pleasant.
    I was about ready to remove the NORITZ and install a storage water heater to resolve the problem. Seems like a step backward so am looking for ideas.
    The MIXET shower valve is a mechanical setting so don't see how that could be changing hot water flow. The only thing that I see is the input pressure change but no one seems to click on that.
    Stan
    A tankless system may or may not have a modulating burner - some do, some don't. If it does have one, it takes it a little time to adjust (not much, but it does), if it doesn't, then the temperature of the outlet will change, sometimes radically, when the volume through it changes. Think about a pan of water on the stove. Put an 1/8-cup in the pan and let it sit for a minute on a hot pan, it may be boiling. Now, redo it and put in a quart of water. After a minute, it will be hotter, but no way as much.
    In the shower, you might be much happier changing the shower control valve to a temperature controlled one. But, even those can take up to a second to follow the and respond to the change in water temperature.
    I think what's happening, is any use of hot water elsewhere is not being responded to quick enough by the tankless system, and the temperature of the shower drops because the temperature of the hot water drops.
    Some tankless systems are better than others. They work best as single use devices, some are okay for multipoint use.
    DIY Member fidodie's Avatar
    Jan 2008
    new jersey
    are you on well water?
    i have a cute two temperature reading thermometer which i have hooked to the input and output of my tankless - and i can see the output shift with input temps - i have a well, so the expansion tank is "colder" than the well water - the well cycles, and i get temperature cycles.
    i think it is an azel unit - runs on a battery.
    i also have a fluke dual probe thermometer (about $100) which i could do the same with.
    both temp gages attach to the pipe with foil tape, so there is a delay, and buffering effect, but it is obvious that input effects output. the fluke is fast sample, the azel is slow.
    if you have a unit that is supposed to create constant temp output, and you are feeding the input water temp in their "temp range" and "flow rate", then it is their unit...
    Pat
    Do it once, Do it right.
    Buy or Rent the necessary tools.
    Call a pro when your skills are stretched too far.
    Mar 2007
    Sacramento
    The NORITZ system has an internal temperature monitoring setup that can be accessed with the control panel. When we went through the check program we could see that the water temp at the input was 58 degree steady. The output also remained constant within a few tenths. So at least the check system sez it is operating oK. Will re-test and watch output temp while changing demand at two or three faucets.
    The local water supply is from wells and stored above ground. The delivery system is all underground for quite a distance. Could the pressure fluctuation at the input cause the output temp to vary? Would the addition of a pressure regulator be a reasonable thing to do? Where would a pressure regulator be installed and what does one look like?
    Do I just have to accept this water heater as a marginal single use device? NORITZ continues to say that the unit is sized properly and will supply two or more showers or appliances.
    Thank you for the thoughts about monitoring the input and output temp simultaneously.
    Stan
    You'll need to try the varying load and see what happens. Note, until you test, you won't know how fast the temperature readouts will respond. What does the spec sheet say for response to a varying load? It's hard to get either an electrical or gas valve to modulate very quickly - there is likely some hysterisis built in which will slow the response.
    A thermostatic shower valve typically responds in 1-second or less timeframes, and might be able to track the variations faster. I don't get big ones at home, but used the same valve in a hotel. The temperature stayed the same, but it also compensated by pressure changes by decreasing the flow; IOW, it used both pressure balance and thermostatic controls to ensure a consistant temperature.
    Someone turning on another hot water tap might not change the pressure enough, so the pressure balance function wouldn't adjust to keep the balance between hot and cold, but as the device lags in adjusting the hot water at the source, you notice it.
    If the sensors at the tankless unit are covered with mineral deposits, they won't respond as quickly as they should. Your system may need a good de-liming.
    DIY Junior Member gmt's Avatar
    Nov 2006
    Pennsylvania
    I assume that you can check on the output temperature at the Noritz. Have you tried flowing water at normal use and when the problem occurs check the output temperature.
    I am not sure about Noritz, but on Rinnai's we can get the outgoing temperature from the control pad.
    If the output temp is at the desired temp. then the problem is most likely with the plumbing.
    Are there any roughed in valves in the house that are not trimmed out? I've found that before, causing a cross connection between hot and cold. And that issue was occasional.
    Just a thought.
    Feb 2005
    Talking pressure flux in system.....
    This might sound stupid, but here goes....
    Occsionally we get water mixing at the laundry outlets....
    Now that you have installed this new system their might
    be something mixing and fluxing at the washing machine...
    WHO KNOWS WHY, it just t happens.....
    try a very simple test and turn of f the hot and cold going to the laundry
    and then take a shower and see what happens......
    if that dont work,
    you might want to change out that crummey Mixit valve
    and install a good 1700 delta.....
    Plumbing Contractor srdenny's Avatar
    SF Peninsula
    Have you asked Noritz to send out a service tech? Did you install it yourself, or did you have a licensed plumbing contractor do it? If the latter, have him go through the diagnostic procedure GMT recommends. It does sound like a cross connection, but checking the output temp at the heater would at least answer whether or not the problem is the heater.
    Mar 2007
    Sacramento
    Question NORITZ TANKLESS temp flucuation
    Well--Sure have some ideas and things to check now. I will be busy setting up some tests and checking temps and flow.
    I did install this heater myself but with the advise and consent of a licensed contractor who has installed quite a few systems and has resolved problems encountered.
    Consensus at this point in time is that the Noritz is working properly and that there must be mixing taking place somewhere. Still wondering about the water pressure flucuation at the input. So will check this all out as best I can. Thank you much for the suggestions. Will let you know resolution.
    Stan
    SF Peninsula
    If you have pressure fluctuations, check the filter at the cold inlet of the tankless unit. It may be partially clogged.
    Mar 2007
    Sacramento
    Default NORITZ Tankless temp fluctuations
    Well----did a lot of testing and other work over the 3 day weekend. Replaced the cartridge in the MIXET and tried a new shower head in the 2nd shoower. I find the 2nd shower works better than the MIXET one so there has to be some undesired temp variations from the MIXET. Alst feel that the water temp seems to follow the inlet pressure variations so the MIXET is more sensitive to that too. The suggestion to set at lower temp on the heater and use more volume also seems to help some. Seems that every thing we touch has impacts on the water temps so everything has to be perfect for the system to be static.
    I looked at the Takagi specs and they are much the same as the Noritz. So if the Takagi seems to be static and works ok for a 2 1/2 bath home then we should be able to make this work. Replacing the MiXET valve is a major project but may be something that we have to consider. Did not anticipate tearing out the wall to get at the plumbing.
    Thank you all for the suggestions and thoughtful replies.
    Stan
    Feb 2005
    Talking Tankless perks
    Shall, learning everything about your plumbing system
    is one of the side benefits of a tankless water heater....
    having to totally "fine tune" the house to accomidate
    the tankless heater and eventually getting to tear
    out that MIXIT faucet is like a perk...
    look at all the "invaluable experience" you got ..
    I honestly hope that you dont have to get into fooling
    with that Mixit valve and everything settles down for you....
    Mar 2007
    Sacramento
    Default Noritz Tankless temp fluctuation.
    Yes I have learned a lot since I started this project. Little did I know how complex plumbing could be. A storage tank evidentally covers up a lot of possible sins in piping, sizing and fixture selection. Fine tuning is the understatement of the day. I will replace the Mixet valve soon. Will go ahead with the bathroom re-do a little sooner than originally scheduled. Looks like about 15 years sinc the last time so will look at a few estimates.
    Will also have the whole system evaluated again at that time.
    Thank you all for your patience and indulgence, Stan
    DIY Junior Member smokey9015's Avatar
    Dec 2008
    Illinois
    anyone know how to put Noritz in to diagnostic/test mode?
    DIY Junior Member icemaniceman1111's Avatar
    Jan 2009
    Massachusetts
    Default strange smell and taste from new noritz
    I am getting a strange smell and taste from a new noritz 931 DV
    A distinct smell of concrete dust/metallic mix
    Upon rinse of mouth with warm water, an odd taste and astringent feel to teeth and gum, almost like a weak acid.
    Anyone else having this problem?
    Noritz denies every having heard of this and so does my plumber and supplier.
    Suggestion from supplier, run it for a week or two and then if we still have it they will send a rep out.
    any thoughts?
    thanks
    david in mass.
  1. Noritz tankless water heater - installed correctly???
    By thediver in forum Tankless Water Heater Forum
    Last Post: 03-28-2013, 09:31 PM
  2. How loud are tankless hot water heaters, Noritz NRC98?
    By lifespeed in forum Tankless Water Heater Forum
    Last Post: 04-24-2012, 09:08 AM
  3. Noritz NR98-OD Tankless water heater
    By Murray1 in forum Tankless Water Heater Forum
    Last Post: 12-07-2011, 03:39 PM
  4. Noritz NR98-OD Gas Tankless Water Heater
    By Murray1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2011, 09:47 AM
  5. On Noritz Tankless why can first vertical run of vent be 3' or less?
    By billhayton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2008, 07:38 PM
