Results 1 to 7 of 7
Thread: Crawlspace cleanup
    DIY Junior Member Billyblackxz's Avatar
    Feb 2008
    California
    Question Crawlspace cleanup
    Hi-I just discovered a leaky galvanized drain pipe under my home.I have since replaced it with black PVC but now have 3-4 places where there are pockets of dirty,stinky standing water.I have cement pier blocks where water is sitting;probably for the last 2-3 weeks.What would be the best way to get this water out of there and what should be done with the moist clay soil?Any help is greatly appreciated!!
    Steve
    Dec 2007
    Pour lime on it!
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    And then bury it with sand.
    Mike
    And then cover it all with visqueen to avoid dry rot.
    wow - I had almost the exact same thing happen to me. I bought a small pump from home depot and pumped the standing water out. After I pumped all the water out I set up several fans to help dry things out.
    DIY Senior Member MG's Avatar
    Jun 2005
    Illinois - Near St. Louis
    Cat litter? It is designed to pickup moisture and deal with odor.
    Note: I am a DIY'er and not a professional. My posts here are observations / opinions and may or may not be in accordance with your local ordinances.
    Feb 2008
    California
    Talking Crawlspace cleanup
    Hi Guys-Thanks for the advice;looks like everything is ok!!
    Steve
