Thread: Diverter valve stem pulling out
    Exclamation Diverter valve stem pulling out
    Forgive me in advance for calling things by the wrong name :-)
    Our tub spout has never diverted 100% of the water to the shower head and has always leaked into the tub a little while the shower was being used. However, now it diverts maybe only 60% of the water. Also, we have to be very careful when we pull it or the stem comes right out. What's the best way to fix this? Do I need to replace the whole spout? There is no set screw on the bottom side of it, so I'm not sure how to remove it if necessary.
    Here's a picture of what I have:
    http://www.flickr.com/photos/23641540@N05/?saved=1
    Thanks in advance!
    Andrew
    Plumber jimbo's Avatar
    Spouts are not repairable. You need a whole new spout. Look near the wall to see if there is a set screw holding it in place. If not, just unscrew the whole spout.
    Dec 2007
    I usually bust off the outer shell of the spout so I can get a holdback wrench on the pipe inside it... Kinda like crackin open a lobstah!
    Default faucet
    That is a Mixet faucet and many of their spouts were slip on with a set screw, but if yours does not have one, then it unscrews from the pipe.
