When the burner is on in my gas water heater I hear a sound that must be a tiny drip of water hitting the burner flame. I'm assuming there is a pin hole in the tank wall in the center flu of the heater.
Some facts here. The heater was installed new in this home 7 years ago, I've lived in it 2 years. I recently disconnected it to put in a catch pan and drain pipe to direct the water over a drop in the garage floor. The heater was sitting on a floor with about a 3 degree slope toward the living quarters. In the process I changed out the copper for flexible conections.
While doing this I noticed the lower 3' section of flu pipe was single wall and it had some major corosion holes so I replaced it with a double wall stack that matched the rest of the flu stack. I also noticed what I thought was a lot of fine debris on the top of the heater tank. I suspect this may come from a combustion problem possibly because of the water leak. I have not seen any water in the new pan.
One other thing here. In reinstalling the heater I replaced the common galvanized inlet and outlet pipe nipples with ones with a lining to prevent dialectric corrosion. There seemed to be considerable crap at the inlet side.
At Last my question!!! Am I correct in that the use of common galvanized nipples by the installer of this heater could have accelerated the corrosion of the tank and the dripping sound I hear along with the crap from the flu on top is all signs of premature failure of the heater?
