Results 1 to 5 of 5
Thread: pump problem
    Default pump problem
    i have a shallow well and a new pressure tank and pump, and my problem is that i cant seem to get the pressure past 35 psi. the problem started with my old pump so i replaced it with another pump, it worked for a week and now i am back to the same problem. i can manually shut the pump off and the pressure stays at 30 psi eliminating the foot valve, i get water when the pump is on and remains at 30 psi for the duration its on so its not frozen, or at least not completely. the tube leading to the pressure switch is clear the water level to the 90 where it leaves the well is approx. 12 ft. the pressure tank doesnt seem to be filling up. i am at a loss here and was hoping someone could give me some ideas on what to check.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    What make and model of pump? If you have a jet pump, with twin pipes going into the well, then there is an ejector assembly in the well to consider.
    Previous member
    Jul 2005
    Riverview, Fl.
    There is a jet in/on the pump if it's a shallow well jet pump. Or like Boots said in the well if it's a deep well jet. With the brand and horsepower along with the pumps specs, we can be more helpful.
    bob...
    its a shallow well pump so just one line with a foot valve at the bottom. honestly i dont know why make, model and horse power would be an issue here, it worked once so something has gone wrong. i'm a plumber by trade, i just dont deal with well pumps very often. i am gonna pull the pump apart and see if there is a blockage as today i cant get the water to flow now
    Previous member
    Jul 2005
    Riverview, Fl.
    The make and model are important because all things aren't what they appear to be.
    If your gauge is accurate and your getting 38 lbs your jet is not plugged. You may have something in one or more of the volutes in the Impeller. Otherwise, I would recheck the water level.
    bob...
