Scott_R
Cursed Dilletente
- Messages
- 12
- Reaction score
- 0
- Points
- 1
I have an unknown 2-wire pump in one of my 2 wells; I'd really, really like to avoid pulling it if possible. The well was running just fine until two days ago, when it simply didn't come on.
I've checked the wiring and I'm getting power at the well head; the pressure switch appears to be in good working order as well.
This well is at about 150ft lower elevation from the house. I've posted about this in the past, but I've had some issues with water hammer in the past (the charge on the tank was wrong) and various 1" fittings in the pit (this is not a pit-less setup) have failed, filling the well cover (pit?) with water. In the past, when the wires have been flooded, the short has kept the pump from coming on.
I had a broken 90deg. elbow replaced last spring, but now something else has failed and the pit is flooded again. I'm running on the first (upper) well, and the check valve there seems to have prevented constant leak-down and cycling.
Anyway - the well cut out suddenly (mid-shower!) on me, and after pulling the cover off, the wires were flooded. I've dried them off, stripped off the badly corroded part, and re-wrapped them, but still no-go on the pump. I need it to come on so I can find where the leak is now, and so I can use it again! Any hints/suggestions? Is there anything to the wiring other than getting a nice, clean connection and using wire-nuts? This is how it was originally done.
