Results 1 to 5 of 5
Thread: Gerber Tank to Bowl gasket
    Default Gerber Tank to Bowl gasket
    I have toilet that leaks.
    After replacing virtually everything not made of china/porcelain, I discovered that the bowl-to-tank gasket(BTG) I installed might be a bit to short
    The BTG installed was 1 1/8", apparently Gerber's need a different product....
    How can a leak located around the tank to bowl bolt be eliminated?
    3. Check the condition of the thick rubber tank to bowl gasket. This is the gasket that encompasses the tank discharge hole and the large assembly nut. Gerber tank to bowl gaskets are thicker than what is commonly found in hardware or home improvement stores.
    .....ok.....so....how thick?
    Navigating the Gerber site was like hiking at midnight with no moon...I discovered the above using Google.
    Searching google again, the thickest BTG I found weighed in at a whooping 1 3/16"!
    Is that 1/16" going to solve all my toilet issues?
    This toilet has a stamp of Feb. 1987 in the tank....and a Gerber sticker still on the side exterior
    Any help will be appreciated.
    TIA!
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    I would check a real plumbing supply house. It does make a difference sometimes. If you installed the tank to bowl bolts wrong it will leak also. If the bolts are not tight enough it will leak. I would double check to make sure that is the problem before you go and get anything else.
    I would toss that toilet in the trash. It is old and should be upgraded to a nice new 1.6 gallon. The money you spend will pay for its self from water saved.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Quote Originally Posted by patrick88 View Post
    No doubt.
    Imagine my surprise when I stumbled across a PSH that was OPEN on a Sunday at 2:30PM
    Community Plumbing Supply Co, Springfield NJ 07081 ...
    At first, I thought it was the bolts - but no water leaked from those areas.
    At one point, the water actually shot the back of the bowl/tank area
    I would....but....this bath is going to demoed in a few months....just need a quick fix until I can toss it all away and drop a Toto in there ! (TY Terry )
    Thanks Patrick.
    DIY Junior Member Kirk's Avatar
    May 2012
    Texas
    Default What Model Is My Gerber Toilet
    I have a Gerber toilet that I need to replace find the correct tank to bowl gasket, but I can't tell what model I have. The only marking I can find is on the inside of the tank. The letter A and the date 1982. Any help would be appreciated.
    Gerber does make a thicker tank to bowl gasket. In hardware stores they are packaged for Gerbers.
    This is for the gravity tanks that use the 2" flush valve.
    The Fluidmaster replacements are too thin.
  1. New tank-bowl gasket doesn't seal
    By teve in forum Toilet Forum discussions
    Last Post: 03-26-2012, 03:47 PM
  2. Mansfield tank-to-bowl gasket for hex nut
    By kurkevan in forum Toilet Forum discussions
    Last Post: 09-27-2011, 06:33 PM
  3. tank to bowl gasket too tall? tank loose
    By 68malibu383 in forum Toilet Forum discussions
    Last Post: 12-15-2009, 07:05 PM
  4. Tank to Bowl Gasket
    By rpinnell in forum Toilet Forum discussions
    Last Post: 10-31-2008, 07:15 PM
  5. Will Gerber tank 28-590 fit Gerber bowl 21-660?
    By average joe in forum Toilet Forum discussions
    Last Post: 03-12-2008, 06:59 AM
