Results 1 to 8 of 8
Thread: Receptacle question
    DIY Senior Member Nate R's Avatar
    Jan 2007
    Milwaukee, WI
    Default Receptacle question
    Any reason I should use the screws instead of the push in connector on a receptacle? Why?
    Dec 2006
    There's not a simple answer to that one, instead there's... a big can of worms.
    Dig in:
    http://www.terrylove.com/forums/showthread.php?t=13968
    the threads I linked, in my response on that thread, are especially tasty.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Only if reliability is important.
    I have repaired a few connections where the sharp device that captures the wire created a nick in wire, which subsequently broke at that point. Since then I have always used the screw terminals if they are available.
    On the other hand, I have some Square D QO tandem breakers from 1965 with push-in terminals that have served more than 40 years without any problems. There is no screw terminal on those breakers so there was no alternative to the push-in terminals.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    They tend to come out or create loose connections. The good receptacles allow you to insert the wire in the hole and then as you tighten the screw it clamps down inside--not just spring fit. Get that kind of take the extra minute to wrap them around the screw.
    Jason
    Central Florida
    Quote Originally Posted by Nate R View Post
    If you ever need to take the receptacle out you'll be glad you didn't use the back-stab. Also, the spec-grade back-stab receptacles I've seen don't allow #12 wire to be stabbed. I agree with Lakee911 -- the best are the back-wired ones that allow you to push the wire in directly, but use the screw to secure it.
    Yes.
    More surfuce area is contacted with this method.
    Jan 2007
    Milwaukee, WI
    OK, points taken. Was replacing a broken light fixture with another one that will only be there temporarily, and the new one had both the slots and screws, so it hit me to ask here about it. I've always used the screws in the past.
    Sep 2006
    MN, USA
    I like the "back Clamp" type better.
    You strip the wire, insert it and tighten the screw.
    Pros
    reliability
    Ease of use
    Cons
    receptacle cost
