If your crawlspace is an unconditioned space the ductwork will need to be insulated and you'll probably will still have cold floors on really cold days. If you insulate the crawlspace and make it a conditioned space, like a basement, the ductwork will not need to be insulated and your floors will be warmer. Years ago builders tended to make crawlspaces unconditioned, like an attic but rooms above a crawlspace will be warmer if a crawlspace is made a conditioned space and it doesn't communicate with the outside.
