Thread: Bathtub overflow drain
    Default Bathtub overflow drain
    Water comes in faster than my overflow drain can get rid of the water. Is this common or is it indicative of a problem with the drain?
    Apr 2005
    Common on all tubs
    Humm, a drain line is probably 1.5", and the supply is probably 1/2" (although under pressure). I'd expect a drain line to be able to handle most supply situations without backing up. While not using the overflow to drain, my tub drains about in half the time it takes to fill up. The overflow goes to the same place as the main drain. Anybody else?
