I would get the Brass Craft no burst laundry hoses. They are a lot better and tend to keep water hammer down. I have installed the fluid master hoses and have had bad water hammer. The fluid master ones seem to use a smaller hose. You should also turn off your laundry valves when not running your machine.
You would also be wise to install a PRV(pressure reducing valve) on your water main. You will also want to install a thermo expansion tank in line too.
