Results 1 to 5 of 5
Thread: Too many bends?
    Default Too many bends?
    Is there such thing as too many bends for a bathroom sink drain line? I am having to get pretty creative to run the drain pipe I want and have ended up with five bends?? Too many??? They are all vertical bends except for one.
    Nov 2006
    Gravity wins as long as the elevation continues to decrease.
    Default elbows
    As long as the drain never plugs up, 5 elbows is okay. Once it does, however, the plumber is going to curse you and your ancestors when his snake/cable tries to go around them.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    The more turn you have the harder it is to snake. Drain cables are less affective the more turns and the greater the distance.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    DIY Senior Member construct30's Avatar
    Jun 2007
    NorthWest PA
    codes require clean outs based on length and number of bends
