On Noritz Tankless why can first vertical run of vent be 3' or less?
billhayton
Installing Noritz 931 and read the first vertical run cannot exceed 3'..if you add a horizontal section and then go vertical again that ok.
Any reason for this...does too much vertical venting cause suffocation of unit?
billhayton
you guys are good...
Makes sense the condensate accumulation is not something noritz or anyone else wants running back to unit.
thanks for the posts
