Results 1 to 5 of 5
Thread: Shower leak
    Default Shower leak
    I have a shower that was leaking behind the walls. When I took the pipe that comes out of the wall off is was broke at the 90 inside the wall. I tried a easy out took and it appears to have cracked the 90. The wall is tile and there is no access. Do I have to take out the tile cut through the wall and replace the 90 ot is there a way to salvage/repair the 90 with a special tool.
    Default Another way to it?
    Well, I'm a carpenter and truly not a gifted plumber, but I do have a few thoughts... If it's copper pipe, you're going to need a bit of room to access it, and the ~1" hole behind the shower arm comes through is probably not enough room (unless you have crazy torch skills!).
    Typically the easier wall to repair is the one behind the shower though, so maybe you can access it through the hallway, bedroom, whatever... it's a lot easier to patch the drywall than the tile!
    Just my humble opinion...
    Plumber RioHyde's Avatar
    Cincinnati, Ohio
    Accessing it on the backside of the tiled wall is preferrable if that is at all possible. Drywall repair is alot simpler than tile repair. There isnt any special tool or technique that will fix the broken 90...it will need to be replaced.
    Hi Steve,
    I concur. Watch out for these plumbers. They'll go in from the front and leave the patching to some poor old tile guy. A tile guy will go in from the back and leave the patching to some poor old carpenter.
    John (a tile guy)
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    Another (better) alternative:
    There are new shower faucet assemblies with large estuchions (chrome or brass finish cover plates) to cover a large hole from the shower side without going through the back of it. They are made to convert former two-handle shower faucets with a single-handle new faucet and for situations like this, and will work great in this instance.
    Check into those at plumbing supply houses.
    Much better than tearing through and repairing tile (which you probably won't be able to match anyway, right John?)
    Good Luck!
    Mike
