Results 1 to 6 of 6
Thread: Why does my shower water temperature gradually get cooler?
    Default Why does my shower water temperature gradually get cooler?
    When I set the water temperature before stepping into the shower, within a minute or so I can feel the water getting cooler. I have to continuously keep increasing the hot water.
    I have plenty of hot water, the temperature just will not stay constant.
    This only occurs in the master bathroom, not the others.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    What brand is the valve? Do the other fixtures in the bathroom have problems?
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    DIY Member fidodie's Avatar
    Jan 2008
    new jersey
    your expansion tank is in a warm area, and the water coming from the water main is colder and mixing with it. the result is the cold water gets colder. This assumes you have a well, and expansion tank and the well is kicking in.
    other possibility is your dip tube on your water heater is broken off.
    cold water gets into the top of your water heater, instead of the bottom...here's a visual.
    it directs cold to the bottom, and pushes hot out the top...
    condo/apartment or home? well or city service?
    Pat
    Do it once, Do it right.
    Buy or Rent the necessary tools.
    Call a pro when your skills are stretched too far.
    Quote Originally Posted by patrick88 View Post
    I replaced the compression valves myself a couple of years ago. I picked up the valves from a local plumbing supplier. Knowing me, I must have done something wrong - so, it could be the valves?
    Quote Originally Posted by fidodie View Post
    Thanks, but since this only happens in the master bathroom I don't think it's a water heater problem.
    Jan 2008
    new jersey
    My Bad - missed that last line......
    Pat
