Results 1 to 10 of 10
Thread: spray foam insulation on pex?
    DIY Member remodelbob's Avatar
    Jun 2005
    Washington
    Default spray foam insulation on pex?
    what type of insulation do you use around pex when going between stories? normally i would use spray foam around the copper and romex, but I am not sure if that will hurt the pex.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    Quote Originally Posted by remodelbob View Post
    Why would you use spray foam? You ever think what a pain it will be to make any repairs in the future. If the pipe chase is in the middle of the house I would not bother to put anything on it. I would only put pipe wrap on any pipes. I think it is alot simpler to use and looks alot nicer.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Jun 2005
    Washington
    i need to get something in there as a fire block. spray foam is fast and easy.
    Sep 2007
    Webster Ma.
    Oh cool I see your point.
    Dec 2007
    Spray foam is rated as a fire stop/block material?
    Dec 2006
    Some of them are.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    DIY Member fidodie's Avatar
    Jan 2008
    new jersey
    I've gotten the spray stuff onto vinyl replacement windows, and it definately compromises the finish. The windows should be tougher, since they need to stand up to UV.
    Rock Wool would allow you to fill the whole (hole?) space. Especially important in exterior of balloon framed homes.....
    Pat
    Do it once, Do it right.
    Buy or Rent the necessary tools.
    Call a pro when your skills are stretched too far.
    I cover about 1í of the pipe in duck tape then I use spray foam. I have used Rook Wool but the inspectors donít like it where Iím at.
    Jun 2005
    Washington
    I was thinking about tape, but I also worry about that compromising the PEX. PEX sure is delicate...
    How about foam pipe wrap and then spray foam around that?
    Sep 2007
    Webster Ma.
    I would do that that. If I had to do what you are talking about I would do that.
