Results 1 to 5 of 5
Thread: moving washer to another room in house with slab
    Default moving washer to another room in house with slab
    i am thinking of moving my washer and dryer out of my kitchen to the garage with access from inside office closet space. The laundry room takes up alot of room inside kitchen and there's no room for eat in kitchen. With laundry room out it will open up kitchen tremendously. I am wondering about what it will require (labor, $$, time involved and who exactly handles this type of work, permits etc..)
    Also if thesable, does the trench dug, have to be in a straight line from first washer spot. The second place i need the washer to be in the garage, there is the garage wall in straight line with it.
    Are there other possibilites, outside etc....?
    Plumber Cass's Avatar
    I would call 2-3 plumbers and get estimates. When they come you can talk to them about You digging, jacking the concrete or what ever they will let you do to lower there estimate unless yop just want them to do the whole job.
    Any of those things you mentioned...indirect routing, outside routing, etc. are possible depending on what you have. Ask the plumber for his input and get a couple of bids.
    DIY Senior Member construct30's Avatar
    Jun 2007
    NorthWest PA
    Make sure they install a proper vent, some plumbers can skimp on a job like this.
    Dec 2007
    I don't see where your from but my question is... Would freezing be a concern?
