R
Rancher
Guest
Hmmm, perhaps a propane torch and a beer can filled with water?
Rancher
Rancher
However, I dont know anyone that would make a joint in the trench unless you have a shield up. You make the joints on surface and toss the string in later.
You said anytime you run PE horizontal... we run it underground from the well pitless to the pressure tank inside the basement of the house. Just like water companies do for service line on their city water systems from the street into the house. And we hang submersible pumps to 500' on it attached to a male adapter x insert fitting on the pitless.Gary Slusser said: Insert fittings are the only type that will work for a pitless adapter or connection to a submersible well pump. Maybe you didn't think of that yet.
I thought of it. I said horizontal. If you got horizontal wells in your area, it would work.....
Because when the pump pulls loose from the fitting and falls to the bottom and I sue you, I will tell my attorney that you used a torch to heat up the pipe and ENDOT specifically says not to use that method.sammyhydro11 said:Who gives a rats ass about ENDOT. Those things are written for people like yourself who are begging for trouble.
You heat it with that torch that you shouldn't be using to heat the pipe with, and I always have 5 gallons of water in my truck, plus a water bottle.Pump installers, and water service installers will never carry around warm pots of water, when there is no water to be had, and no way to heat it.
