Results 1 to 2 of 2
Thread: drop in tub used as a shower too?
    DIY Junior Member Don's Avatar
    Dec 2004
    New York
    Default drop in tub used as a shower too?
    K-1257
    Mariposa™ 6' Bath Whirlpool
    I bought and installed a 6ft Kohler Mariposa whirlpool drop in tub..display model..got it cheap..I haven't installed tile yet on the 2 X 6 decking or the 3 wall surround....I'm a shower person...Is using one of these as a shower going to be a water disaster?..does anyone out there live painlessly with this configuration?..should I build up Hardibacker on a slight slope and bullnose tile at the top on the fiberglass?..any suggestions?..Thanks ..Don
    Don -
    I would install a clawfoot tub shower curtain (you know, the full circle type). Then, I would duct tape, nail and staple (twice) plastic around the entire enclosure. Showering with a rain coat and rubbers would not be a bad idea either. After each shower I would squeegie, towel dry and then blow dry the entire surrounding area. You know, all of this could have been avoid if you had just installed a drain in the surrounding tile area around the tub.
    Still your friend & neighbor.
