Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Power cord for plama TV
    Default Power cord for plama TV
    The cord it comes w/ is SJT cable and isn't as long as needed. I bought another cord but realized it's SVT.
    I don't know much about the difference, but doing some research, looks like the SJT is for hard usage/service and the SVT is a vacuuum cord.
    1) What does hard usage/service mean?
    2) Can I use the SVT cord instead of the SJT?
    Gehrig
    Central Florida
    Looks like the main difference is the SVT cord is designed to be more flexible. They're both rated similarly, although SJT is available in larger wire sizes. Oddly, though, one vendor's 12-3 SJT is only rated for 10A, the same as the 18-3 SVT. Let's wait for BobNH to respond; he'll know.
    Thanks for the response.
    I forgot to mention that both cords are rated 18AWG / 3C.
    Central Florida
    I'm pretty sure either would work fine in your application.
    The big thing probably is how much longer is the new cord? A plasma doesn't draw a huge amount of energy, but then 18g isn't all that big, either. If you are going to buy one significantly longer, I'd probably want to go with a heavier gauge wire. You don't need the PS working harder than needed because of voltage drops.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    just out of curiosity, where is this tv located that the cord will not reach a receptacle?
    DIY Member enosez's Avatar
    Jan 2007
    Long Island NY
    What exactly is a "plama" tv?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    18AWG wire is good for 7Amps, I believe. That should be enough for atleast 800 Watts. If you want to consider the voltage drop, it'll be approx 6.5 Ohm/Foot.
    I would just get a 14AWG three-prong extension cord and use the stock cable.
    Jason
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Lakee911 View Post
    Jason
    I would just rough in a new receptacle behind the tv so you dont even see it...
    Are you running this extension cord inside the wall so the TV installation looks neat ? It is against the Code to run extension cords inside a wall or cabinet. It is OK to run TV and computer cables inside a wall.
    Central Florida
    That doesn't sound right to me, but I can't check the details right now. Maybe off by a factor of 1000 or so.
    Aug 2005
    Columbus, OH
    Quote Originally Posted by Mikey View Post
    Yup. Off by 1000. That's the resistance per 1000ft. Sorry about that.
    http://www.stealth316.com/2-wire-resistance.htm
    Sep 2006
    MN, USA
    Quote Originally Posted by enosez View Post
    http://en.wikipedia.org/wiki/Plasma_display
    DIY Senior Member mikept's Avatar
    Jan 2008
    CT
    Lakee did you mean milliohms? Or were you sugesting toaster wire?
    Last edited by mikept; 02-12-2008 at 04:51 PM. Reason: aftermarket spark plug wires too high
    Aug 2005
    Columbus, OH
    Nope. I meant 6.5Ohm/1000ft.
    See this chart http://www.eskimo.com/~billb/tesla/wire1.txt which I just googled real quick. It says for 18AWG: 6.3851Ohms/Kft.
    Jason
