Results 1 to 5 of 5
Thread: temporary power pole
    DIY Junior Member toolguy504's Avatar
    Dec 2007
    Chalmette, Louisiana
    Default temporary power pole
    I am putting up a temporary power pole and I would like to know if the conduit going from the meter pan up to the weather head has to be rigid metal conduit or can it be rigid EMT conduit or Schedule 40 conduit. Also does it mater if the weather head is metal or Schedule 40. Thank you.
    Earl
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    I would check with your local Power company, they may and usually have their own request along with following the NEC and any state amendments....
    DIY Senior Member BrianJohn's Avatar
    Jun 2007
    VA
    Not sure if your utility has any special requirements, but in our area temporary services use SEC* cable and plastic weather heads. IT IS ONLY TEMPORARY as the saying goes.......................
    *service Entrance Cable.
    In the Trades brownizs's Avatar
    Feb 2006
    Springfield, IL
    All that I have seen, are wired as if it was on the house (Weatherhead, Meterhead, Main Breaker Outdoor panel, and either 3-conductor #1 or #2, or Conduit depending on the regulations in the area.
    Aug 2007
    Litchfield, CT
    If I was doing the job I would just use SEU, but it really depends on where you live and what is acceptable...
