Don't caulk around the faucet, Christine. That would just make the water go behind the wall. You definitely don't want that! I would remove the faucet and start over. Clean off all the old tape that you put on. Then re-tape, using a few more turns than you used the last time. Remember to always tape in such a way that turning the faucet does not unravel the tape. I think that would be in a clock-wise direction in your case. You might also purchase some pipe dope and apply it after taping as extra insurance towards good seal. Of course, if you bought a plastic faucet and cracked the threads (or stripped them) this does not apply. Also, if you loosened the fittings behind the wall when tightening the faucet. (Not a plumber, just a lowly handyman.)
