you have probably beaten it ...
but you should really tighten down that
ball adjustment ring....that helps a lot sometimes
occasionally a delta will develope a leak around the
actual Stainless Steel insert where the washer is seated..
you have to look really close at it for signs of decay
and leakage or deformanity around that SS seat...
odds are you have probably won
