Thread: can you give me propper name these tools
    Default can you give me propper name these tools
    i know the toilet auger water shut off and the trap snake but not the name of the grabber thing in the pipe thats like 8' long and the plunger thing on the long rod
    Plumber Cass's Avatar
    You have it right, 1 is an 8' grabber thingy and the other is a plunger thingy on a rod.
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Probably for grabbing or plunging something, eh?!
    Dec 2007
    The plunger is commonly used to clear a clogged house trap. I use a snake with a 3" blade to push through the trap then run lots of water to wash out as much of the debris in the trap as possible them vac out the rest.
    The plunger is a fast in and out job that does not do a good job of cleaning the trap. Good for repeat business though!
