Hi,
I have discovered my toilet is leaking at the base. It appears to have been doing this for quite some time as it appears there is water damage on the wall. The toilet is an American Standard Cadet elongated low flow. From looking at it, the tank is jammed against the wall and the toilet it higher off the floor in the back than in the front. It measures about 11 inches from the wall to the bolt holes. I'm concerned that the cause of the problem is the drain pipe is too close to the wall for the toilet and the original installer forced it to work.
Any advice? Will a drain offset solve this problem and allow for 12 inch rough in? I would like to replace the toilet with a Toto Drake because it has never done the job very well but i need to solve the rough in problem and the leak.
Thanks,
Dave
Thanks,
Dave
