Results 1 to 14 of 14
Thread: 1.3 GPF in California
    Default 1.3 GPF in California
    Somebody said supply house told them that 1.6 GPF Toilets were not going to be sold after July 2008. Appears Gov. Arnold vetoed in 2006. Anybody know the current status?
    Plumber jimbo's Avatar
    Sacramento conveniently hushes up any publicity on consumer issues like this, just like you have not probably heard about the 2008 light bulb laws, which I just talked about down in the electrical thread.
    At some date, and I don't know for sure if Jan 2008 is it, but at SOME date, they will start phasing in the 1.28 gallon per flush. What it
    means is that each manufacturer will have to make a certain percentage of their total production in that setup. The first year, which may be now, the new ones will be available, but there will only be a few. Each year for about 4 years if I remember, the % will increase, until by about 2012, then 100% of toilets sold in CA will have to be the 1.28GPF
    I would suspect, but have not read, that some water districts will do what they have always done here since 1990 on 1.6.......mandate a 1.28 gallon be installed on the sale of a house. At some point, it will be mandatory on remodel and new construction, and I do not know if that date is now or 2012.
    This is all a good question to run at your state assembly man's office. But I would not expect quick response right now, as they are gearing up to do battle with Arnold's proposal to close state beaches to balance the budget!! Arnold.....have you lost your ^#%^@# mind??? This is CALIFORNIA....SURF CITY.......home of the Beach Boys! Close the beaches over my dead body!
    In my home, I was using the dual flush Toto Aquia in the main bath, worked very well.
    One bathroom has a 1.1 gallon Vortens
    Downstairs has a 1.6 Ultramax,
    I have changed the main bath to a 1.28 gallon Eco Drake.
    Dropping to lower flush volumes isn't going to be an issue it seems.
    Thanks for the quick responses. And I guess the Golden State needs the lower GPF's with the recent years low rainfall and population growth.
    Plumbing Contractor srdenny's Avatar
    SF Peninsula
    HET (High-Efficiency Toilet) wc's (1.28 gpf or less) will be mandated in California as of 2014. The late date is the result of a deal struck between the various conserving interests and the domestic toilet manufacturers. The manufacturers got the extra time by promising to push HET technology nationally, with the EPA also planning to support federal policy backing HET.
    DIY Senior Member mikept's Avatar
    Jan 2008
    CT
    Why dont they mandate dual flush by 2014, austraila already does, and israel has for over a decade. California seems to go pretty far on environmental stuff, suprised their taking it easy here.
    SF Peninsula
    Dual flush is one of the HET options. The other two are gravity and power assisted flush.
    Jan 2008
    CT
    How do they weight the big and little flushes to get the average gpf rating?
    SF Peninsula
    Jan 2008
    CT
    Quote Originally Posted by srdenny View Post
    that link is broken
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    They want to save 0.32 gallons per flush while they put billions of gallons of water on the desert in and around Los Angeles to make it green.
    Central Florida
    Quote Originally Posted by mikept View Post
    that link is broken
    The link given contained "hard" ellipses -- probably came from another reference. If you go to the root (www.cwwa.ca), you can chase down various publications on your own. I think this is the one you want, and it's hot off the press -- Jan 14, 2008:
    http://www.cwwa.ca/pdf_files/Map%201...%20Report1.pdf,
    and here's another one that may be of interest:
    http://www.cwwa.ca/pdf_files/Drainli...on-Apr%201.pdf.
    Central Florida
    Quote Originally Posted by Bob NH View Post
    If you add up all the .32gpf savings, you get billions more gallons you can waste in the desert.
    SF Peninsula
    Not to mention all of Arizona, Nevada and a good chunk of the rest of the west.
