Results 1 to 9 of 9
Thread: Gas black pipe plug
    DIY Senior Member rockycmt's Avatar
    Nov 2007
    New York
    Default Gas black pipe plug
    I am going to turn out a 3/4 inch plug tonight that looks pretty well doped up and dry. Is there any advise as to how to start? Do I just give it a whirl or should I put something on it to loosen it/penetrate it.
    Also, how do I properly clean the old threads to accept my new line?
    Central Florida
    Non-pro advice: scrape off as much dope as you can easily get rid of, give it a few squirts of PB BLaster (I may have the initials wrong), come back after a while and give it a whirl. Use two wrenches so there's no torque on the pipe.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    Quote Originally Posted by Mikey View Post
    You should always use two wrenches so you don't loosen another section or torque the pipes.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Doing your own gas piping and you don't know how to take out a plug?
    Make sure you alert the neighbors so that they can get pictures for the eleven o'clock news.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Black Pipe Plug
    Quote Originally Posted by Herk View Post
    YES "PLEASE" LET US KNOW YOUR LOCAL NEWS STATION SO WE CAN WATCH ALSO,
    MACPLUMB 777
    DIY Junior Member Buckeyetech's Avatar
    Jul 2007
    3/4" pipe probably won't require much more than a couple of 14" pipe wrenches.
    Default plug
    The plug should unscrew easily, and why would you need to clean the threads if a plug has been screwed into them?
    Jun 2007
    Licensed Grump
    I'm with HJ & MAC...it's ok replacing a faucet, repairing a drain or a leaky water line.
    Gas is a different ballgame.
    One very small leak inside and it can gather until it's sparked.
    Dec 2007
    Mmmmm, Make a mistake with gas piping and your house could sneeze... If your still alive afterwards you will own a pile of toothpicks!
