I had a new 50 gallon, gas powered, Bradford White water heater installed a short while ago. The plumber that did the work said that the unit had some kind of "hydro-jet" action and wouldn't require periodic draining. The manual, confirmed also with a call to the manufacturer, says it's best to drain off a gallon or so monthly to prevent sediment buildup. The plumber said doing this would eventually wear out the drain valve and that it's not worth the effort.
So......is it a good/necessary maintenance practice? I've kind of split the difference and drain a couple of gallons every six weeks or so and don't see any sediment or cloudiness to the water.
