Results 1 to 8 of 8
Thread: cutting pipe
    Cool cutting pipe
    hello,i am having a problem cutting the galvanized drain pipe under a house.using a reciprocating saw and laying on my back ,i seem to have a problem of cutting it straight.is there a secret or a guide that i should know about.thanks jvl
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Keep the shoe of sawzall flat against the pipe.Start out slow untill cut to
    inside of pipe.SAFTY GLASSES!
    DIY Member JeffH's Avatar
    May 2006
    California
    Default Take your time...
    #1 - Wear safety glasses
    #2 - Practice on scrap pieces.
    #3 - Use the right size/type blade for the job.
    #4 - The shoe is meant to be a guide for leveling and stability. Hold the shoe tight to the pipe. Lock your arm against your body for stability. When you start to cut while keeping the shoe against the pipe, let the tool do the work. Eventually, you'll get a feel for when to apply more/less pressure. Just like welding/soldering it's always good to practice on scrap pieces to build confidence.
    Dec 2007
    Put a lenox gold blade in that saw!
    Galvanized is not so hard to cut. Use a new metal cutting blade. Are you sure it's not cast iron? That's different!
    Dec 2007
    The lennox gold will do the cast iron too... Recently I used the same blade
    1 1/2 days on a job cutting cast and galv.
    Jun 2007
    Licensed Grump
    Try a Milwaukee "Torch" blade.
    Lennox is the name I usually get for hole saws and blades, but the Torch's are fantastic.
    Default cut
    wrap a paper strip around the pipe and mark a straight line. The cut to the line.
