Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 87
Thread: Shower handle sticking out too far
  1. #61
    How many have you installed? Because my contractor installed one with the plaster ground flush with the finished wall, and so did many others on the Internet (you can do a search), and the handle still sticks out too far (unlike the picture). That is why I made my post, that is why mrhutton made his post, and that's why when you search "moen shower handle sticking out" you find several forum and blog posts also detailing the problem. The problem is that the plaster ground thickness is overly conservative so that a little variation won't make it impossible to shut off the valve. Rather, better to be able to shut off the valve and have something that's a little less cosmetically pleasing.
    If you're going to insist that everyone complaining about this problem is an idiot who is unable to align a piece of plastic with a finished wall, then so be it. Here is one example of someone who experienced this problem. There are others.
    http://forums.construx.com/blogs/ear...-and-moen.aspx
    This is another, "I WANT my Moen valve to look like the one on the display board", when that one was NOT assembled according to Moen's specifications. Moen has a plastic "plate" that is designed to be flush with the finished wall, and WHEN it is installed that way, the handle looks EXACTLY like the ones shown in these pictures. YOU, the customer, can install it with the plate anywhere you want it, because if the handle doesn't fit, it is YOUR problem. IF I install the valve, I will use Moen's specifications, regardless of what you WANT, because otherwise I may have to furnish an extension which will place the handle even further out.
  2. #62
    the valve depth is incorrect. If the wall is open behind the shower valve, it would be best to loosen the trim plate and back the valve up and secure it to a backing or support. Those valves usually come with a black plate that allows for it to be installed at just the right depth.
    Plumbing Solutions, LLC
    Your Local Plumber in Columbia, S.C.
  3. #63
    If you set the valve at the correct depth, the handle does stick out farther.
    That still works fine, but it won't look like the catalog picture.
    Are you even surprised?
    Try installing a toilet when the catalog conveniently leaves out the water connections.
    Yes, that's right Mame, I had to connect water to your toilet,
    Yes, it didn't show water connections in the catalog, that would have been in the instruction manual.
    Yes, it's a big connector for a $2400 toilet, but you see, since there is no tank, it needs that large volume connector.
    You can't always trust the catalog picture, those come from very artistic people. They sometimes "improve" the photo to make the catalog look better.
    Not real world though.
  4. #64
    Did you ever notice that EVERY toilet picture shows it against the wall? But, I can guarantee that fewer than 1% are that way when they are actually installed. I am surprised people who complain about the shower handle, do not complain about that also. It is the same thing.
  5. #65
    DIY Junior Member mrbaseball2usa's Avatar
    Jun 2010
    Alabama
    Quote Originally Posted by mrhutton View Post
    To be clear - the problem with the bad aesthetics is due to Moen's incorrect instructions.
    The Moentrol valves come with a plastic disc affixed to the face of the valve, and this disc is clearly stamped "IMPORTANT! THIS SURFACE MUST BE FLUSH WITH FINISHED WALL".
    And if one abides by these instructions (i.e., setting the valve in the rough framing with the face of the disc protruding ~13/16" past the face of the studs to accommodate .5" Durock + thinset + .25" tile), then yes, the back of your finished valve handle will have roughly an inch of gap between it and the face of the escutcheon when in the "off" position (and will surely make your wife cry).
    This is exactly what I ran into on my Price Pfister, and now I'm dealing with the same issue of roughly 1" gap between the escutcheon plate and the shower handle. Still researching the best way to overcome.
  6. #66
    If you have a problem with the projection of the handle, EVEN when it is EXACTLY where the Moen specifications call for it, regardless of WHAT the Moen "experts" tell you, then call Mike Holmes of "Holmes on homes" and he will tear your entire bathroom apart and put it back together any way you want it, or more precisely the way HE wants it.
  7. #67
    DIY Junior Member andy911's Avatar
    Aug 2010
    toronto
    Default Ugh - this got me too
    Just finished tiling my shower stall and installed the moentrol Icon hardware, and sure enough the handle is sticking out like a sore thumb. If anyone has a picture of the fix with the escutcheon extension I'd love to see how it looks.
    I have a couple other questions about this hardware, which feels *incredibly cheap* to me:
    1)The handle is ridiculously flimsy - there is just a very large amount of flex to it. I'm guessing the plastic piece that is used to attach the handle to the valve is the culprit. Since the handle is lever style every time you pull it in and out it flexes, and just feels very cheap. Is this the typical experience?
    2)The face place shows that hot is on the left and cold is on the right. The lever handle faces down (6 o'clock) at mid point. This would imply that a clockwise turn (from 6 o'clock to 9 o'clock) would get more hot and counter clockwise (from 6 o'clock to 3 o'clock) would get more cold. However the adjustment to limit the hot water limits the amount of counter clockwise rotation - in effect limiting the cold! How can this be?
    Really really disappointed with this hardware - I thought Moentrol was some of the best around? The tub filler is also garbage - the water spits and splashes out the bottom, and when you pull the lever for shower theres still a lot of dribbling coming out of it....
  8. #68
    The valve depth is incorrect. There usually come with a black plate that puts the valve at the correct depth. When we put in valves on our new construction site, we put up a backing preset for the correct depth and and we screw the valve to the backing. (A backing is just a 2x4 cut to fit in between the studs of your wall and nailed up to support the valve.)
  9. #69
    A pressure balance valve starts out all cold, and the scald limit just limits how far you can turn it to the hot side...that's the way all of that type (that I've seen) work. The extension kits that I've seen can compensate for the valve being too far embedded in the wall, NOT for already being too far out of it. I always suggest people put the trim on and mock it up to determine where THEY want the handle to be before installing and mount the valve accordingly. There is a min/max, but really, those are just the limits of where the trim will fit, not necessarily where YOU will like it. And, there doesn't seem to be a convention of min/max. Personally, I like the handle closer to the wall than the max projection, but based on the manufacturers of these things, if it fits, it's right.
  10. #70
    Aug 2010
    toronto
    PlumbPowerHouse, if you look at this thread you will see that the Moen plate is quite simply wrong - if you follow it the handle sticks out 3/4". Jim, IMO you are giving Moen too much credit by using the word "right" - it may be acceptable, but it aint "right"
    I figured out that with the Moentrol if you turn the value 180 degrees it reverses the hot and cold. Too bad the face plate is right when the hot water stop is wrong (or vice versa)! Again, a poor design. I also figured out the flex in the handle is as much the valve itself as the plastic coupling - I guess when you have that long of a lever handle its pretty easy to jiggle. Probably should have got the Grohe - those felt rock solid.
    Here's my next question - how can I "increase" the usable range of warm water with this valve? I find that the only range on the lever that isn't freezing cold or blistering hot is from between around 5 o'clock and, well, 5 o'clock. (4 o'clock is scalding and 6 o'clock is cold). The valve I bought has stops - can I slightly trim the hot supply? I don't particularly want to turn the water temp down on my hot water heater. Is there another adjustment?
  11. #71
    FWIW, the recommended outlet temp of a WH for most domestic use is 120-degrees. You can run the tank hotter, but it is suggested that you install a tempering valve (they are required where I live, but they don't dictate what you set it to). Some DW like the temp hotter, but many also have heaters to get it that way.
  12. #72
    Aug 2010
    toronto
    I don't think I have my WH set abnormally hot - it was simply set by the installer as they would normally set it. I'll double check it tonight.
    Anyways, I'm thinking that reducing that temp would simply move the sweet spot on the lever, but wouldn't widen the range of usable temperature any.
    I'm going to play around with adjusting the hot pressure by trimming the stops - I expect that to work but I fear it is going to reduce my overall shower water pressure too much.
  13. #73
    quote; 2)The face place shows that hot is on the left and cold is on the right. The lever handle faces down (6 o'clock) at mid point. This would imply that a clockwise turn (from 6 o'clock to 9 o'clock) would get more hot and counter clockwise (from 6 o'clock to 3 o'clock) would get more cold. However the adjustment to limit the hot water limits the amount of counter clockwise rotation - in effect limiting the cold! How can this be?
    Because you are completely incorrect. The handle does NOT point to the temperature, the TOP of the handle, it if had a pointer on it woud do that. ALL the handle does is rotate from ALL COLD, on the right, counterclockwise to ALL HOT, (or warm depending on the limiter stop setting), on the left. IT does NOT limit the amount of cold water. IT limits the amount of HOT water and thus ALL the available cold water produces a reduced temperature warm water.
  14. #74
    Aug 2010
    toronto
    You're right - but isn't it crazy that the handle points to the opposite labeling on the escutcheon? there's nothing on the top of the handle, why would anyone assume this is the way it operates? Again, very bad design.
    I'm actually going to reverse it to make it do what I want, and not use the hot water limiter (or else drill out the collar to put the limiter screw on the other side)
  15. #75
    DIY Junior Member dustindriver's Avatar
    Aug 2010
    Bend, OR
    Hi alphonse55. I know your post is years old, but I just wanted to let you know that I have the same problem. I just moved into a house in Bend, OR, and the original late '90s Moen shower handles stick out about 1.25 inches. I replaced the whole shebang—cartridge, handle, cover plate—in one bathroom and the new one sticks out as well. Seems the original contractor didn't put the valve back far enough. In this house the only way to fix it would be to open a wall and redo the valve or replace the fiberglass tub and put in drywall and tiles.
    The reason I'm writing, however, is that I believe there could be a fix. All we need is a thicker cover plate, one that covers the distance between the shower wall and the faucet handle. Maybe we could modify old hubcaps? Anyway, Moen should make some sort of wall cover adapter to bring the cover closer to the handles in installations like ours. I'm going to call them to see if it's a possibility.
  1. Shower handle and trim for 22 year old pull-out handle
    By Steveindanville in forum Shower & bathtub Forum & Blog
    Last Post: 12-23-2009, 10:27 AM
  2. single-handle Aqualine shower handle
    By marchat in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2006, 02:18 PM
  3. Convert 2 handle to 1 handle shower/tub
    By Pgannon in forum Shower & bathtub Forum & Blog
    Last Post: 04-26-2006, 09:08 PM
  4. two handle vs single handle tub/shower
    By PaulHG in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2006, 02:08 PM
  5. handle sticking
    By wjd in forum Toilet Forum discussions
    Last Post: 10-06-2005, 08:46 AM
