Results 1 to 10 of 10
Thread: Pegasus Shower Tub Valve Problem
    Default Pegasus Shower Tub Valve Problem
    I recently turned on my secondary shower to find that the hot water side of the divertor no longer produced hot water. I removed the trim plate and could see nothing out of the ordinary. Any suggestions on a fix? the unit is basically new as it is only used when company is in town. Unfortunately I have company for Christmas and no hot water -- please I need help.
    Thank you
    Dec 2007
    The balancing spool is stuck! It is an internal part. The valve needs to be disassembled are you going to DIY or, call a plumber?
    Default Pegasus shower tub valve problem
    DYI I took the internal apart and found nothing ?? nothing appears to be stuck, the spool was moving freely, there was 2 ports I presume hot and cold. However I can only get cold out of the volumne control valves, the adjustment screw on the hot turns in and out but no water will come out until the cold adjustment volumne control is turned out. Even when I take out the stops on the spindle shaft and free spool the valve 360 degrees I still get no hot. It will shut off in 2 spots as I turn the spindle but no where on the rotation will it give me hot. The vanity beside the tub gets hot though???
    Dec 2007
    Have you got the model # handy?
    Jun 2007
    Licensed Grump
    Bingo.
    I had the "pleasure" of installing just one Pegasus..sold to the customer by HD.
    The balancing cartridge ceased in the time it took to put up drywall & tile.
    You can tell it's stuck by shaking the stem while it's out...the cartridge will rattle if it's working right. It slides inside the stem freely.
    I've installed a couple of pegasus faucets. I thought they seemed like very high quality. Has the experience been that all pegasus stuff is junk?
    Tom
    Junk?
    I wouldn't say that.
    Last year the Pegasus shower valve had no tolerance, so if you missed the rough-in by 1/4" you were in trouble.
    This year I installed one, and the tolerance was better, not much, but better. The directions were wrong though. If I had followed them, it would have been a mistake.
    For a retrofit, it's a different pipe measurement from the wall than for Delta or Moen.
    that means you need room to add fittings to make it work.
    It would be nice if their designers were working in the same world we are in. They didn't have to make it so hard to work with these things.
    With so much Delta, Moen and Grohe to be had, why would someone buy Pegasus?
    Dec 2007
    This is a screen shot of the 1/2 time ad Pegasus played at the super bowl last year...
    Well okay its better than Glacier Bay!
    Jun 2007
    Licensed Grump
    Dunno 'bout that...the real kicker is Pegasus is kinda pricey to top it off.
    Default Pegasus Shwr valve
    The valve seems OK, I have another Pegasus in another room and when I exchanged the balancing cartirdge it made no difference. I still had no hot water. Is there a specific way these need to go in? or isd there a trick to the install I am not seeing? Is there any other adjustment on these? I have tried all else outside of changing outn the valve. Does Pegasus have replacement parts available and if so were can I find them?
    Quote Originally Posted by GrumpyPlumber View Post
    Bingo.
