Don't think male metal into female plastic is legal in any code...
That being said, I prefer to use half of a SCH80 PVC nipple into the female brass valve body then glue the PVC into a coupling and then to the pipe...
The SCH80 nipples do not break as easily as the MIP fittings and other male plastic adapters I have used...
If the connection has to be disassembled frequently you can use a union (or banded coupling if the application is not a high pressure one)...
