Results 1 to 12 of 12
Thread: red triangle on water meter
    DIY Member econguy's Avatar
    Apr 2007
    Massachusetts
    Default red triangle on water meter
    Hi
    I recently noticed that the red triangle on the face of my water meter was moving back and forth by about 3/4 of a revolution. Each time it moved forward-backwards-forward, it ended up a little past where it was.
    I didn't have any fixtures, etc turned on while this was happening. Is the only cause of this a leak somewhere? And why would it be moving backwards?
    Thanks for any feedback
    Will
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    Meter leak indicators can be a little "sensitive". They spin very rapidly when any water is running, and should be at a stop when not.
    Do you have traffic going by nearby or anything else that might be causing it to move? Public water pressure fluctuations?
    Dec 2007
    Time to check all the faucets for drips and dye test the toilet tanks.
    Default red
    If it is moving back and forth, then it is responding to pressure fluctuations. A leak would make it rotate.
    Dec 2007
    Time to check for leaks!
    Licensed Grump GrumpyPlumber's Avatar
    Jun 2007
    Licensed Grump
    Lets place bets, mine is on a leaky flapper.
    "The biggest regrets we have in life are the chances we never took."
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    I would check the water level of the toilet(s). I once had a toilet fill to the top of the over flow and stop then drain down the overflow then fill again. It was a stop go stop go. Then again a bad flapper will do the same thing
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Jun 2007
    Licensed Grump
    Quote Originally Posted by patrick88 View Post
    Dam, ya got me, I shoulda just generalized and said toilet...good point.
    Apr 2007
    Massachusetts
    Thanks for the replies, folks.
    I'll test the toilets and faucets this weekend, and post an update with any findings.
    Will
    Dec 2007
    That is also what happens when a bowl refill tube is too far down the owerflow tube and the tank water level is set too high.
    Sep 2007
    Webster Ma.
    Quote Originally Posted by Redwood View Post
    Ya I tend to install the air gap so that doesn't happen. Saves the call backs for something that could have been prevented with one minor piece.
    My vote is for pressure fluctuations. I agree that if something was using water, the indicator would only move in one direction.
