Thread: Sewage Pump Smell
    Default Sewage Pump Smell
    Hi,
    I have been working this issue on the pump section and it was suggested I post this on the plumbing side to see if there are any plumbers out there who can help.
    I have a terrible odor from my basement sewage pump. I have bar sink almost directly over the pump that I have draining into the pump via the vent pipe. Is this incorrect? Would this cause the smell? What can I do to eliminate the problem?
    Attached is a drawing that shows the sewage line with the check valve, and the vent piple with the sink draing coming into it from the back. I have caulked with scilicone the all of the fittings and seals, and I still have the smell. Any thoughts would be appreciated. I can't stand it any more.
    Dec 2007
    See your duplicate thread under pumps & wells
    http://www.terrylove.com/forums/showthread.php?t=17527
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    From your pix I see the discharge pipe (pvc) is primed so I assume is also glued. I can see the blue on the pipe. I see some blue on the vent but can't tell tell on the 90. I would check all joints and after taxing all options I would smoke the tank to find the bad joint. That would find it
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    If you try "smoking the tank" be careful about the source of smoke. You can get an accumulation of methane in there. Methane + spark/heat =seals can be replaced after the shrapnel is removed. You could maybe use the exercise to celebrate new years eve tomorrow. A column of flame from the roof vent would be cool.
