Conduit for Ethernet
Seaneys
Chicago Suburbs
Hello,
I'm curious what everyones thoughts are for conduit for use with ethernet / video branches?
I've seen the blue flexible conduit used on our area. Doe sit work well?
Steve
JWelectric
North Carolina
Depends on the application of the raceway, around my area the cable is installed without the use of a raceway in over 90% of installations.
Furd
Engineer
Wet side of Washington State
I am currently doing Ethernet, telephone and television cabling in my house and I am using a combination of rigid PVC and flexible conduit.
I am using the rigid for main runs to and between junction & pull boxes and then the flexible to the individual branch access points.
It makes for a VERY neat system and because most of it runs in my crawl space it also protects the wiring from rodent damage.
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
I didn't use conduit when I ran Ethernet, telephone and television cables and everything worked well.
One note: Don't use metal conduit with Ethernet or telephone cables since they are sensitive to nearby metal. They do make conduit ready wire, but it's better to just use plastic conduit.
Seaneys
Chicago Suburbs
I may need to pull wires after they insulate.. It is getting cold here..
interalian
Calgary, Alberta
Really. My office building runs 100/1G ethernet throughout, all inside metal conduit with about 60 home runs to the switch room. The conduit originally housed 25 pair telecom wire for the old Nortel SL-1, then was re-wired for arcnet (coaxial cable) and digital phones. The arcnet cables were replaced with Ethernet in the same conduits. Never a problem in 17 years.
