Results 1 to 8 of 8
Thread: Whole house surge . . .
    DIY Junior Member sjh's Avatar
    Nov 2007
    California
    Default Whole house surge . . .
    protectors, worth the money? I am in Southern California where they do not even ground television antennas!
    DIY Senior Member BrianJohn's Avatar
    Jun 2007
    VA
    Whole house surge suppression is worth the money if, it is a high quality TVSS, properly installed (most are not properly installed), preferably with led or neon's to let you know it is working. Then use point of use plug strips or plug in TVSS at the equipment. Once again high quality with leds to give notification of faulty TVSS.
    The TVSS at the main service will provide some protection and the point of use adds protection, minimizing possible surge damage. BUT understand mother nature can through a lightning strike that NO TVSS can protect against. Depends on amplitude, duration of the strike and where it hits.
    Central Florida
    Read the product and installer's fine print very carefully. I was all set to sign up for TECO's "Zap Cap" program, but their fine print said, more or less, that everything was guaranteed unless something went wrong. I'm still looking for a whole-house solution that I will probably install myself. For now, I've got APC UPSes on all critical gear.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    At least for Square D QO you can get one that plugs into any pair of slots in your breaker panel. Plug it in and connect the wire to the neutral bus. It's hard to mess that up.
    Plumber jimbo's Avatar
    Unless you live in the mountains of S. Cal, lightning is extremely rare, but it does happen every few years!
    If you have a lot of money invested in computers and A/V equipment, it is worth taking care of this stuff.
    Most surge surpressors, especially small and inexpensive ones, will offer some protection against transient high voltage surges.....microsecond duration, thousands of volts. But they are in a relatively low joule range.
    What they don't protect against, and what can damage everything from the computer to the refrigerator, is power line surges from the power company. These may be anything from just a few % surge of voltage, to something in the hundreds of volts, but of much longer duration. The joules surged will smoke most surge surpessors. You need a much fancier device to protect against those. You would need to check the specs.
    Here is a link to a good tutorial on the power supply subject:
    http://www.falconups.com/pdf-04-2004...s_tutorial.pdf
    Jun 2007
    VA
    APC UPS do have some level of TVSS but are off line devices and do not offer protection from utilities issues some folks think they might. Good devices and do give stand by protection and some level of surge.
    Most APC UPS's are Single conversion compared to double conversion that offer line filteration, seldom needed in a residential application
    Nov 2007
    California
    Default I have it down . . .
    Sep 2006
    MN, USA
    I bought one from Me****s and wired it into a breaker.
    I also added an extra ground rod and have protection on the cable and phone wires.
    Each computer area then has Ethernet, phone, and power protection again.
    The idea is to create a island so that even if the ground voltage rises the equipment sees the same voltage on all the wires going in and out.
    So first line of defense is to tie heavy wires between the ground for the telephone, cable and electrical protection. In a way the power utility in a large city does this for you.
    The second line of defense should be at the computer with all the lines in and out of the computer are protected. The protector's ground voltage may rise, but it will be ok as long as it's not grounded again after the protection.
