Results 1 to 10 of 10
Thread: Toilets with vented bowls for less smell
    Default Toilets with vented bowls for less smell
    Here is a vented bowl for the bathroom to reduce smell.
    There is a remote fan, with piping to the back of the bowl to suck out the smells from the bowl.
    Shown with controls and fan.
    The connection at the back.
    DIY Member MarkHash's Avatar
    Mar 2007
    Wisconsin
    For those of YOU
    Who like to BREW
    DIY Senior Member achutch's Avatar
    Oct 2005
    Vermont
    Another old idea that became new again, this time with the benefit of forced air.
    When I was in the 5th grade, we were moved to the so called "old school" in the village where I grew up. The bathrooms were in the basement and the toilets were ancient with painted steel tanks and washdown bowls, each bowl with a side vent. This vent was connected by ductwork and exhausted into the chimney (this chimney non-functioning as the stoves in the classrooms had been removed long before my time). My guess is that the hot smoke from the stoves would pull air through the vents in the toilets and help to reduce "bathroom odors" (as they were discretely referred to by the air freshener ads back in the 1960's). Of course I remember that basement sanctuary smelling more of gray oil base deck paint and Blox Fresheners (paradichlorobenzene moth cakes or urinal blocks).
    These new vented toilets ought to be installed where I work. I sometimes have to hold my breath as I walk through the men's room to get to my locker. The air in there is often rank with evil that brewed within (of course not within me, LOL) and made its ghastly escape!!!
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    Good lawd!!!
    What have the Japanese wrought now?
    LOL
    The inventor is from Oregon.
    I'm trying to find his name again. I just found these pictures I took, now I need the name.
    And a good cure for constipation! Just turn up the fan . . .
    Seriously, I see a problem with an overflowing bowl.
    Mar 2007
    Wisconsin
    That stall has more push buttons than the space shuttle. "We are go for separation". I would probably have a micro-switch under the seat for activation of the power vent.
    Plumber Cass's Avatar
    The only problem that he needs to address is the possibility of water building up from condensation in the vent piping below the fan.
    I would guess there is a market for it, albeit a small one.
    Default venting
    Wouldn't that be an interesting unit to rough in. We have enough problems trying to get a finish wall measurement for the shower, and now we would have to know EXACTLY where the finished floor would be so the vent opening could be positioned, AND THEN try to fit that thing onto the vent and the closet bolts, while not damaging the wax ring. Maybe it is made of plastic, so at least it would not weigh half a ton.
    We would have to know EXACTLY where the finished floor would be so the vent opening could be positioned
    The final connection is behind the tank. A small hole in the drywall, and a flex connector goes to the back of the bowl.
    For condensation, the connector should grade down toward the bowl.
    The extra switches are for extra bathrooms. All bathrooms could be piped to the same fan.
