Install of Kohler k-14489 valve
backwaterdogs
Illinois
Hello all, new to this site, hope you can help.
I am installing a shower valve onto plumbing already roughed in by my plumber as this is a bathroom project we are finishing on our own after the rest of the house was completed.
The valve will be behind a tiled wall with no planned access from the other side(other than tearing out drywall).
I have 4 questions. The first in regards to the valves in the picture. The plumber put these valves in but I'm not sure if they should be removed or left since there will be no planned access. Is it a good idea to have valves buried in a wall w/ no access?
Question 2 is regarding the support of the valve. Is what is pictured ok.the valve is resting on the 2x4 on the body of the valve.
Question 3: should I also in stall hammer arresters at this valve in the wall?
Question 4: I'm a little confused about the plaster guard. I have to have the valve all the way against the backside of the drywall to make this fit. Does sound right for a k-14489 in 2x4 wall, with about 3/4" total of wall board and tile?
thanks very much!
Jimbo
San Diego, CA
Those ball valves will probably outlive the house, so no harm leaving them. The only good reason to have them is convenience ...like now, during the remodel.
The valve needs to be attached to a crossbrace of some kind, to prevent movement in the wall, even though is sounds like a tight fit.
Hammer arrestors could be used. We don't use them much around here, but some people like to use them.
As far as placement of the valve, the installation instructions and that plaster guard fitting give you the specific placement of the valve with respect to the finished wall surface. If you don't follow that spec, you will have problems attaching trim and handles.
backwaterdogs
Illinois
Thanks, Jimbo!!
1 more question about the crossbrace....I interpret what you said that I need something behind the valve to strap to well.
I think I can rip some 3/8" plywood and then use strapping material to fasten the valve body to the plywood.
Would this suffice? There aren't any flanges w/ holes cast in the valve .... straps seem to be the only way to fasten this thing.
thanks again!
