Thread: Square D panel?
    Questions from readers Guest's Avatar
    posts, emails and comments from readers reposted by Terry
    Default Square D panel?
    I have an old sq.D panel CAT. QON-12M. Is it possible to purchase tandem breakers for this panel? I need to add more circuits.
    Roy
    Default panel
    The schematic inside the cover will usually tell you if they will fit, but normally if it can use tandem breakers the model would end in two numbers. One is the total standard breakers and the other is the maximum using tandem breakers. The difference between the two numbers is the number of tandem breakers possible.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Worst case scenario just add a sub panel...
