Thread: New Washing Machine
    Default New Washing Machine
    I an installing a new front load washing washing and running the drain tube through the second floor instal location and out by normal means. The instructions tell me to instal a syphon break 29 inches from the drain tube.
    What is a syphon break and why do I want one.
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    If the washing machine drain hose can not be looped higher than the water level in the tub, you'll need to install a syphon break. If you don't install one, the tub will never fill as water will be syphoned out as fast as it goes in.
    -Sam
    Thanks Sam. So if I buy a longer drain hose, loop it above the machine and still use the floor drain, all should be good if I read you correct. Same principle as a dish washer.
