I'm replacing an old combination meter and breaker panel that feeds my barn and hayshed. I really don't want to replace (or have an electrician replace) the entrance cable, but the Homeline unit I've bought is very long and the cable would have to be long enough run through the panel, down below the meter socket and curve 180 degrees to attach to the meter socket. This would require mounting the panel very high to avoid replacing the cable.
Does anyone make an "old style" combination that has the meter above the breaker panel which includes a main breaker? Alternatively, I can use a separate outdoor meter box and mount an outdoor main breaker panel below provided it's acceptable in my jurisdiction.
This would be a very straighforward job if I could find a panel in the original configuration.
I'm open to suggestions.
Rick
Rick
