I share a well with my neighbors who live about 20 vertical feet up a hill from me. They have an issue with losing (completely) water flow sporadically. They had someone come to inspect the system who raised the cut-in pressure from 40 to about 48 psig. Cut out is at 60 psig. That helped for a while, but they recently had the problem again. I did some troubleshooting and found that after turning off the pump, they can still get flow at least down to 25 psig, slow but not completely gone like when they have this problem. Pump seems to cycle normally when I check it, but the problem is so sporadic that I haven't been abe to check the gage or pressure switch status when they have no water.
At my house I never lose flow. When they lose flow, they can turn on a faucet at my house until the pump comes on and they get water back after the pressure is higher. Seems to me like a sticky check valve at their house is the problem, but I have looked and don't know where it would be. Any suggestions? I'm concerned about having the range at 48-60, but the pump does cycle at least 2 minutes apart when I have a faucet running, i.e. no cycle issue (I think). Where should I look for the valve? Thanks in advance!
