Thread: Wiring Solenoid Valves for Sprinkler Manifold
    Default Wiring Solenoid Valves for Sprinkler Manifold
    Hello. I have my manifold built, valves installed. Control mounted, etc.
    All I have to do now is figure out how to wire the valves to the five wires( I used a five wire jacket - four zones and common, right???)
    Any feedback is greatly appreciated.
    I beleive figure 8 in this page is what I need. Is there anything else I should know?
    http://rainbird.com/pdf/diy/man_CP.pdf
    Default wires
    That is about it, except to be sure to use waterproof wire nuts for the connections.
    Plumber jimbo's Avatar
    Pick a color....let's say white. Call that common. At the controller, connect that to the "c" or "common" terminal. At the valves, take one wire from each solenoid ( doesn't matter which wire). Tie those all together. If the valves are not close enough, you may have to spice in extensions. Connect the white wire to that bundle.
    Then at the controller, red goes to #1, blue to #2, etc. ( color code is completely dealer's choice). Same at the other end.
    Default Thanks Fellows
    My installation took place without any problems. Of course figuring out how to program the timer was another story - but the installation went well.. Again I owe thanks to this forum for the assistance I receive.
