GrumpyPlumber
Licensed Grump
Any of the instruction I've read on those presoldered fittings said you still had to add solder. A stupid concept in my opinion.
I like the tinning flux. I've never had a problem with it. It won't work on any of the older solders, 50/50, but no one should be using that unhealthy stuff unless you want to be tarred and feathered. It is designed for use with silver solder.
I won't even use it on DWV, it runs much thinner and the hubs on DWV have less surface area, as well as more play.
95/5 all the way...then you don't have to play around with that roll that has the ripped label to guess if it's lead or not.
