You need to find out where the holding tank is because that is more than likely your problem. Either the inlet of the tank is clogged or its waterlogged. If you dont have a holding tank, one needs to be installed with a pressure switch and relief valve mounted in front of it. I have only come across one system without a holding tank and for some odd reason the pump lasted 3 years.
Sammy
