sink not draining / just roughed.
Terry896
I was asked to move a waste drain for a new vanity from existing 18" up to 24 1/2" so that i would not cut into a fixed shelf, so I changed the rough.
Now after all the sheetrock / vanity / sink is installed, the water does not drain. It just sits in the basin waiting for something to happen, and eventually does drain.
I am assuming that my waste is now to high. If it is, how can I lower it, without cutting into the fixed shelf? The bottom of the trap is about 2 inches above the shelf at the moment.
Frenchie
Jack of all trades
I'm not sure I have your setup pictured right, and I'm not a plumber. But instead of changing the rough, couldn't you just extend the standpipe, and have the trap under the shelf?
Winslow
Hawaii
as long as te trap arm enters the tee below the bowl of the sink it shouldn't matter. Sounds to me like someone poured something down the drain during construction (drywall mud and paint being the usual culprits)
drain
high or low, it is immaterial if all you did was move the elevation of the tee in the line. Either something is in the line, or we are not getting the correct information.
WestcoastPlumber
Plumbing Contractor
los angeles
www.wcplumbing.biz
lowering or raising it does not mater, as long as you are draining below the sink.
Sounds like you need a drain cleaner to go and snake the drain.
I was on a job once, new construction, the owner pissed the plumbers off, fired them, they came back sometime and dumped 2 x 4's and chunks of wood down the vents, along with other debris, a 3 story house with an elevator, very bad situation, it was all walled up and completed, no one knew until is was finish time :eek:
BAPlumber
Vashon, Washington
If that's the case he has a whole different problem since the water is draining.
I once had a job where a deflated clean-seal (Cherne) was left in a drain line. It would plug up and let a little water pass.
Frenchie
Jack of all trades
Old Mason's trick: put a pane of glass halfway up the flue of every chimney you build. If the guy doesn't pay you, leave it there. His chimney won't draw, he looks up, no obstruction...
When you get paid, drop a brick down the chimney.
