Thread: HVLP Paint Sprayers - outdoors
    DIY Senior Member rdtompki's Avatar
    Dec 2005
    Iowa
    Default HVLP Paint Sprayers - outdoors
    I've done a lot of exterior painting with airless paint sprays, but I've got to paint 350 fence posts (installed) and I really want to use a sprayer. My trusty airless would waste 2/3 of the paint. How well would a good HVLP sprayer work outdoors if I only use it under calm conditions? I know I could use a brush, but the plastic mesh nailed to one side of the round fence poles will make using a brush very difficult.
    Rick
    DIY Junior Member RBM Ent.'s Avatar
    Dec 2007
    New York
    If you use your airless with the right tip; such as a 211 or finish tip it will save on paint and it has a small enough spay pattern 4" so you don't over spray as much.
    Dec 2005
    Iowa
    Thanks for the response. I'll look into this since I already have an airless. Got to figure out a good way to drag a generator and airless through the pasture.
    Rick
    The best way to do a job like that is to have a painting party.
    Invite about 30 of your closest friends and give them each a paint brush and a gallon of paint. You'll have it all done in a couple of hours. And all you have to do is man the BBQ and supply the beer.
